J joeyjmeyer New Member Feb 2, 2009 #1 Feb 2, 2009 #1 I have just got a brand new honda 6.5hp clone. And the throttle only stays in one place when you move it how can i change that.
nostrixoxide New Member Feb 2, 2009 #2 Feb 2, 2009 #2 joeyjmeyer said: I have just got a brand new honda 6.5hp clone. And the throttle only stays in one place when you move it how can i change that. Click to expand... Well you can always make, modify or purchase a new throttle linkage. But first I would check to see if something is binding up...
deezildennis Active Member Feb 2, 2009 #3 Feb 2, 2009 #3 Are you saying the lever is real tight? If that's the case you need to lossen up the pivot nut on the linkage to allow it to spring back..
npatton19 New Member Feb 2, 2009 #4 Feb 2, 2009 #4 What he said^^ Did you even try and fix the problem?
