Take the handlebars off!
The Murray has the pivot tube welded at the bottom and a top retaining plate. The top plate cannot be taken off with the handlebars on! Take the top nut off and remove the handlebars and the top plate. From there you need to loosen the nut that holds the bearings in place. Once all that is out, the forks will slide out the bottom of the head tube
