The title basically says it. It's got a new ignition coil; the carb has been douched quite well; it has spark, but the only way I can get any firing out of it is with the choke wide open and even then it'll sputter for a few seconds, and die. Could it be flooding itself out? It take a few pulls each time to get the sputter. I set the points at .20 and the spark plug gap at .30. Not 100% sure I got the timing set at the exact BFDC point, but it is close. Could this be the issue? I'd think I could at least get it to run, even if not too well, but run none the less if the timing wasn't perfect.
