I have a DB 80 that I have recently engine stalled to a heavily modified 212 needless to say it need to stop better. I purchased a hydraulic front brake kit for a Coleman CT200U and it is too wide for the front forks. does anyone know if OEM CT200u forks will fit a DB 80? any other suggestions on how I can adapt this kit to the bike would be grateful!
It won't fit. Return the parts if you can.
The parts that Charles S posted are what you need. I've got that setup on a couple of bikes and it works well.
You will want to run one of the cheap hydraulic rear setups too. I don't know what a DB80 is and I'm guessing you don't know what you have. The rear hydraulic kits are bolt on for the DB30, but the MM80 needs a special bracket. Post pics of your bike if you want people to tell you what works for your setup. I'm guessing you're confusing the DB30 and MM80 and getting a DB80, which doesn't exist. That can be an issue when it comes to parts compatibility.
