on jackshafts, i use set screws FOR NOTHING. drill/tap the ends of the jackshaft, and use a 5/16-24 bolt at the jackshaft ends. NO collars with set screws. And spacers DO NOT add friction, there's no grease involved! the fact that you even said that means you're missing the whole point of spacers, and do not understand their function. and there's no rattle either if you're using the correct material for spacers. watch the video i posted above. it explains it all. Spacers are more elegant, and make the jackshaft far easier to service, and spacers make the jackshaft WAY more dependable. and you guys understand that center collars with set screws removed are just spacers that are too short! and using collars at jackshaft ends is again, amateur hour. it's just something big to rotate and catch your shoe or ankle upon. ever have your shoe lace eaten up by a jackshaft collar? ha!
i find it adorable that you guys do all these engine mod for performance and dependability, but then cheap out with set screws and collars on the jackshaft...
