"I Think I Have Gas..."
Hey guys FatBuddyCat here and I'm in a situation.....does this look OK? Are the tanks too low? Easier to lift the tanks, lower the motor or add a fuel pump? Is there a belt shorter than the standard 30 series plate units? 20211219_132023.jpg 20211218_220441.jpg 20211218_214856.jpg
It should work ok if the tank is full, but when it is low it is about the same level as the carb and may not empty. There are many different length 30 series belts and charts for them. Look on the OldMiniBikes warehouse for the chart. you need to measure center to center length of the driver bolt to the driven pulley center and then use the chart to find the correct length.
toomanytoys
Measure center to center driver to driven.
Google belt tav 30 belts. Bmi has a good chart. It will give you a range. Like 6" to 7" use this belt.
I believe there are 2 shorter belts
