It should work ok if the tank is full, but when it is low it is about the same level as the carb and may not empty. There are many different length 30 series belts and charts for them. Look on the OldMiniBikes warehouse for the chart. you need to measure center to center length of the driver bolt to the driven pulley center and then use the chart to find the correct length.
