Sorry, I should have resized the photo
You need to loosen the two bolts that hold the coil. You may as well take it off and find your fire wire.
It will be thw wire attached to a metal prong coming out of the coil.
Put the coil back on, snug up the bolts then back them off to just loose.
get some plain writing paper an fold it once. Slip it between the coil & the flywheel.
Tighten the bolts well, but not too tight, they are small an easy to brake.
Then remove the paper, the coil should not rub the flywheel.
