it won't just bolt in. the stock 2.8 has a different mounting pattern than a 6.5. you'll need to drill/slot new holes. you will have to buy a new clutch too. the 6.5 has a 3/4" bore (the 2.8 is 5/8") and you'll need one for #35 chain.
the throttle hook up is different. you also need to decide if you want to keep the governor installed. do a search on here for info on the throttle, it's been covered many times.
if you remove the governor, it's generally a good idea to go with a billet rod and flywheel. those two mods will run you around $180 after shipping (check
ARC Racing Home Page ). they help with performance but they're more of a safety thing. the stock rod and flywheel weren't designed to run at the RPMs you'll turn without the governor. if either of those let go, it can be very bad for you.
the best advice i can give you is to start reading in the doodlebug and honda/clone sections. you will probably find many answers to all of your questions there.
if you have any more questions, just ask.
