I was working on getting the Aggie running right since it would struggle to turn on and at wot. I removed the idle needle/jet to see if it was dirty from sitting but it wasn't the culprit.
It would start easy with some gas down the carb. I knew the carb had been rebuilt so I focused on the pick up tube thinking it had a crack or hole. Thankfully it was just the brass pick up tube that wasn't connected to the carburetor so I just had to tap it back into the carb. Briggs starts easy on first pull now. Hope this helps someone else.
Now for a noob question..... Is this some kind of brake lock on the hand lever? I've seen brake lever locks on the old bmx freestyle bikes but don't look like this lever. I've sprayed some Kroil on it before I try to get it moving. The trigger doesn't move and don't want to force it. Brake lever works fine though. Any input will be appreciated!
