This is cool...first-hand input from two guys modifying doodlebugs in different ways...excellent photos, too.
I bet that bigger engine swap really perked up the performance...
I don't know if that axle-mounted caliper mounting bracket for a pocketbike will work or not...that rotor on the doodlebug isn't the same as the ones I use, but if the diameter of the rotor is the same size, the pocketbike mounting bracket would work, just enlarge the axle hole to doodlebug axle size.
I have some rotors that are larger, and I make brackets from 1/8" sheet steel that are a little longer than stock to compensate for the increased diameter of the rotor...
These aren't difficult to make, but they can also be purchased from pocketbike parts suppliers for just a few bucks.
The positive aspect of this type of caliper mount is it turns the rear wheel/brake into an independent subassembly, and can be easily moved from side to side in the frame to adjust wheel alignment, or even flipped around, putting the brake on the other side to make installing a jackshaft easier.
I haven't hit any pocketbike parts supplier sites lately, but if the doodlebug is anywhere near as popular as pocketbikes have become, these guys will eventually offer some performance mod parts for them...the sites have several mod kits for the 49cc bikes, but the cost of the parts might make it less attractive than swapping to a bigger engine...if the swap isn't that complicated.
ForeverYoung...how did that swap work?
