I picked up a replacement 12.5 Briggs for my tractor, came off a model very close to mine and even included the pulleys so I didn't have to swap mine over
The new motor top plate was missing the piece holding the oil dipstick so I just swapped top plates off my old engine
Hooked up the fuel line and linkage, motor fired on the first try. Blew out some white/grey smoke for about 20 seconds then ran nice and strong. Shut it off and noticed some gas coming back out of the carb. The one on my old motor is recently rebuilt so I figured I would just swap them over.
As I was removing the carb from my old motor I found another problem on top of the cracked block. The intake manifold was cracked all the way through and barely held in place by the top bolt only.
Also the plastic fuel line connector cracked (was brittle from age) so that cost me a whole $4 to replace.
Tractor looks worlds better also since I hit it with the degreaser hose while the motor was out and cleared up years of gunk built up in there.
Under $100 total invested (including new oil, fuel filter, degreaser and the cracked fuel fitting) and the tractor is back in the game!
