I am building up at least one maybe two 80212 3hp engines, most likely 1968 date coded. Regarding the side case covers they used (ribbed with the 4 mounting lugs) I am pretty sure that they only had one oil fill hole drilled with a fill plug??? If so was in the front or rear??? Anyone lucky enough to have an original from say 1967-69 that can verify? Both the ribbed sidecovers I have are dual fill so I would like see if I can modify and permanently install a fill plug so it looks more correct once assembled and painted, gotta do some JB welding on the old blocks anyway to fill the points plunger holes as I am installing magnetrons on all of the early blocks I am using, may as well do it all at once.
Thank you!
Thank you!
