Hi! New on the forum, not the planet
I've searched the site and the Google pretty hard, and have a few questions for the experienced GX/Clone guru's.
I want to build a couple of governed clones, to make lots of power without major revs. Maybe 4k tops. Cheap!
I have a pair of new 212's but will be R&D'ing on a 196 Lifan.
So far, I have a bare 14cc head. I'll do mild porting and a good valve job.
Plans:
Flat-top Honda Piston. I know, no eq for the 70mm, but I'm working on that.
Advance timing per dyno (building one now)
Jetting, obviously
Air filter and adapter
Header. LONG
1.2-3 Yamaha rockers
Advanced cam timing per dyno
I'm having a hard time finding springs that won't bind at .300 range lift, and not be too stiff for stock cam.
On E85, Can I trim the flywheel fins a bit to lessen drag? I'll likely use a thermal barrier coating on piston, chamber and ports, so it should be a chilly bugger.
Am I on the right path?
Plans:
Jetting, obviously
Header. LONG
