So the Delta 1 chopper I picked up the other day has some serious slop in the headset/fork/steering tube. a 1/2" bolt fits snug in the fork plates, but has play in the tube. It almost seems like it should have a bushing or sleeve between the bolt and the tube, but there isn't one. Did these bikes come with a thin-walled nylon bushing or something in the headset?
I don't have a bore gauge or calipers to get an exact measurement, but with a tape measure the ID of the head tube is definitely larger than 1/2". I can almost get a 9/16" drill bit in there, so I'm thinking it's in the neighborhood of 17/32" ID.
Here you can see the space around a 1/2" bolt. Seems to be concentric, not "egged out".
Same story on the bottom:
I want to ride this bike, so getting the steering right is definitely a priority. Could I use nylon shim stock to make a bushing of sorts? Or does anybody know if 1/2"ODx17/32"ID brass or bronze bushings are available anywhere?
