Just scored this bike as a roller from my new friend and semi-local minibike buddy Tiki_Todd. All original except for the front wheel. Working on finding the correct 6" Manco wheel for the front. Someone also cut the foot pegs off. Came with a newer H35 that I will use for now, until I can dig up a more era-correct HS40.
Some hurdles will have to be overcome. Lower fork tubes are locked up tight in the forks, zero suspension travel in the front forks. Have them soaking in PB Blaster right now, will see if that helps. Also, the steering tube/neck is super sloppy. Uses a 1/2" bolt, fit is good at the fork plates but sloppy in the tube. Any suggestions for dealing with that issue? Could I shim the neck tube for a more snug fit?
I would almost hate to strip this one down to bare metal since it still has most of the original paint, and a glossy re-paint would make the chrome look worse by comparison. So I might just clean it up, buff it out, and keep the ratty/survivor look. Let me know what y'all think!
