I bought first mini bike. to bad it is chinese but whatever.
I will take fenders and put lower profile old school tires.
What can you guys and gals recommend ?
THANK YOU
Our son bought an 8hp Predator 301cc for a gokart project and he wanted to know what performance parts are available? I'm not sure if gx270 or gx340 parts interchange or if this engine is all by itself... any info would be great.
Like the title says...will a Coleman Attex Sport gas tank work on a Rupp Roadster?
Even if I have to cut the seat pan a little bit, that would be okay with me.
I saw one for sale on the web...but the guy is too lazy to give me any measurements.
I don't understand people, guess he really...
Hi, I got the OldMiniBikes throttle kit from our fine host and am having trouble figuring out what goes where. The kit is the small kit, TD_KM194 for about 9$ not the 28$ kit. My motor is a Greyhound and I'm wondering if this kit is not compatible. There are no instructions with it but I looked it over...
Has anyone tried using these rims on a FOX spoke wheel series bike? Street Scamp, Trail Tramp, Campus FX, Trail FX...
https://www.OldMiniBikes.com/10-Steel-Wheel-Chrome-Plated-Less-Bearings.html
fits, original spacer and drive cog work?
Working pull start assemble for Tecumesh. Only issue is chip in handle and a some scratches in the bad over sprayed paint.
$20 shipped to you door.
https://drive.google.com/file/d/0B0v4U_rswuqdOUxtMEJxYXV2TTQ/view?usp=sharing
1970 Rupp Roadster-
Installing some new wheel bearings and notice that they drop in a little TOO easy into the hubs. I am used to having a nice (lightly) press fit, so they do not rotate in the hubs. What are some techniques you use to snug them up a bit?
Michael
I called the parts store the dude said that's how it fits and on top of that the hardware they sent with it was mixed matched and used.. Carb to manifold
Gotta Briggs coming that was built up, its an 80's engine. anyone know if this carb style will still fit the old flat tank bolt pattern and tube holes? I want to use my older shrouding with Aluminum recoil and flat tank for a more period correct appearance.
I bought a brand new Stock Box clone 5yrs ago with all the go fast goodies...
Arc Flywheel
Valve Springs
Intake
Exhaust
Cam
Jets
Rod
I never installed any of it. Recently I bought a Hemi predator 212 which I installed in my doodlebug. I was wondering what would fit the? Seems...
new carb. never seen gas. 20mm copy of the briggs raptor PZ22. it will fit tecumseh with minor modifications, the manifold holes need elongated about 1/16" of a inch and possibly make a gasket instead of the supplied Oring...... the choke lever may need bending too. i have had good luck with...
Hi everyone. A few years back my grandson wanted a mini bike so we built one from a kit I bought on line. After a few weeks of watching him ride, my daughter insisted he not go alone, he asked me why I don't build one for me? Then we could ride together.
Well that's what I did. It had to be...
