Questions about moding Massimo Warrior 200 Beginner
Hi guys new to this sub had been looking on it before I decided to get the mini bike.
https://www.massimomotor.com/MB-200
I have few questions on mods.
I want to mod the bike but do not want overly complicated altering like grinding, welding, cutting. I do not have tools for it too. Based of research I found I could add torque converter, air filter change, carburetor, sprocket.
I have stock engine do I need to change it to predator 212 or it is sufficient if I add other mods.
Which comet torque converter or centrifugal clutch do I buy?
Will it require any modifications to fit? I saw TAV one required change. There is also 30 or 40 option which one do i choose?
https://www.monsterscooterparts.com...r-kit-for-predator-6-5-hp-8-0-hp-engines.html
Is it 3/4" or 1"?
What sprocket to buy? Is 60 teeth good?
https://www.monsterscooterparts.com...Wi1JcgNYUu-yEzEFOlyWRR1QTCrl4TeEaAhUlEALw_wcB
https://www.amazon.com/Bracket-Barr...+seat+kit+for+mini+bike&qid=1603356778&sr=8-1
What modified air intake jet to buy?
Does this include all of it
https://www.monsterscooterparts.com...5-mb200-baja-heat-mini-baja-baja-warrior.html
What is the cloth cover which everyone has on there? Is it needed?
What exhaust header pipe should I buy?
I don't want to make it louder so I can add muffler. Right now the bike is too loud and I hear some rattling metal noise I need to check what it is and maybe tighten everything. Is there any mod I can do. I bought it from store where they tightened and all.
https://www.gopowersports.com/stage-1-coleman-ct200s-mega-moto-212-performance-kit/ (expensive)
What carburetor to buy?
Do I need high end or any from amazon can work
https://www.gopowersports.com/22mm-mikuni-carburetor-performance-kit/
Is there any speedometer/odometer that can fit?
Back light ?
Turn Signal?
Do I need this?
https://www.monsterscooterparts.com...ble-massimo-mb200-mini-bike-threaded-end.html
How about the rear suspension? Is there a mod available.
Can I just use this spring or it will not work?
https://www.amazon.com/HANSWD-Brack...+seat+kit+for+mini+bike&qid=1603356778&sr=8-3
Thank you
Is it 3/4" or 1"?
Back light ?
Turn Signal?
Do I need this?
Thank you
