I've been lurking around here a lot in the last few months. I've learned tons while putting together this predator 212 that I am using on a duck hunting boat. What I thought was going to be the last part of the puzzle is driving me insane...the mikuni 22mm knock off.
mods on the motor are arc flywheel, arc rod, black mamba jr, 26lb springs, straight exhaust, and a uni on the mikuni.
I have a fair amount of experience with carburetion on harleys and dirt bikes but maybe I'm missing something with these little motors. I'm losing it, it's duck season out here in Utah!
I've spent the last 3 days trying to get this mikuni right. I got the 130 and 12.5 jets with it since, after reading a ton, that seemed to be a fairly safe bet. Put the jets in and put the carb on and it fired right up but goes straight to 5-6000 rpms and stays there.
I've spent a ton of time going through the mikuni manual, the agk post and saw a good post on diygokarts.
I've thoroughly gone through the whole tuning process with the mixture screw and idle adjust multiple times. Idle adjust on the side of the carb is functional, moves the slide up or down easily. Turning the mixture screw either way does nothing. Which makes me think air leak.
I've checked for leaks around the manifold. Got no change in revs spraying carb cleaner all around it.
new gaskets and I used some high temp on the connections as well.
Tried the 15 pilot jet. no change at all.
Tried different clip positions on the needle with all of the previous combinations.
I've cleaned the carb and jets, re cleaned, and cleaned again.
The throttle cable isn't keeping the slide up either-thoroughly dealt with that.
Does a insulator need to be run with the manifold in this situation?
Could it be that I need to go all the way to 17.5? I would think that if that's the case, the 15 would at least show some sort of change from the 12.5
Through all of this, now I need a new float bowl gasket and a new mixture screw. Seems like there is fuel coming through the threads of the mixture screw. Didn't think that was possible.
Anyone know where to get a mixture screw for the 22mm (that's not on ebay shipping from China)
I really appreciate any insight.
and thanks for everything I've already learned from you guys' previous posts.
