so i now have a big block 5 horse tec for my rupp tt500. i have been messing around with the carb just trying to get it in tune. i haven't quite been able to get it perfectly dialed in yet though. here are some of the problems that i would like help with.
#1 starts well when cold, runs for a little while and slowly starts to lower the RPMs until it dies.
#2 after it dies it can sometimes take a lot of pulling to it it going again, when you get it going step 1 may happen again.
#3 if you pin it right away it basiclly kills the engine, doesn't really boug out or anything just doesn't fire. However if you SLOWLY bring it up it works.
#4 When giving it FULL throttle with the plate as far open as it will go, completly fighting off the govener trying to bring it down. It starts to missfire, pop, kackle, not run good, until you let off the gas a bit then it sounds and runs better again
thanks in advance for the help
