Motovox MBX10 GX390 Throttle linkage
A fellow Forum member asked for an explanation of how I made my throttle linkage so here it is.
I started with a 10/32 coupling nut in which I drilled a small hole towards one end large enough to insert the throttle cable thru and secure with a short screw. Make sure the hole is close enough to the end so the screw intersects the hole and you are able to tighten the screw down against the throttle cable to retain it. I found some 10/32 screws at the hardware store that had a 1/2 inch of thread with a larger head to act as a shoulder. Turned the other end of the coupling down in the lathe to form a shoulder. Turned it down just enough so it fit thru the existing hole in the throttle arm without any slop. Turned down two nylon washers to ride on the shoulder of the coupling nut to act as a bearing surface. Put one washer between the coupling nut and the throttle arm on the top and the other underneath. Made sure the washers were thick enough so the coupling nut didn't rock around when tightened up but still was allowed it to rotate. When you install the screw to secure the coupling nut to the throttle arm use a dab of blue Loctite to make sure it doesn't come loose in the future.
I removed the wave washer and nylon washer that was under the throttle that added tension to the arm and discarded them. You don't want the wave washer to bind the arm, you want the arm to be able to move freely so the throttle doesn't bind. I chucked up a piece of nylon in the lathe and drilled a hole in it that was large enough to fit over the shoulder on the throttle bracket that the arm pivots on. Turned the nylon down to 1 inch OD and cut off two washers to act as bearings using a parting tool. Put one washer on the bracket, installed the throttle arm and put the second washer on top of the arm. You may want to put a dab of grease on the washers. Reinstalled the arm retainer and secured it with a new locking nut. Snugged the nut down enough so the arm still has free movement.
I have this used this same setup on another GX390 to adapt the hand throttle to cable activation and it has worked great so far. I used the existing cable retainer that came on the throttle bracket to secure the throttle cable. I guess you could make up a threaded piece to hold the cable so you could fine tune the adjustment of the cable but I found no need for it. You can cut off the extra part of the hand throttle linkage if you feel the need. Hook up a return spring and you are ready to go. Hope I haven't bored you with my long winded explanation, just wanted to make sure I explained it as best I could so others could duplicate it.
