Bought another MTD Columbia roller from a detroit guy. The frame was cracked in many places, got that all sorted out. Had it powder coated in a (somewhat) original orange color. Re-did the stickers from the front fender, clutch cover, and gas tank. The HS50 Tecumseh is a re-done snowblower motor that runs great. Overall came out well. The prior owner had already bought new shocks and tires and seat, which was nice. Made restoring this example a lot easier. Unfortunately he did not include the rear sprocket or torque converter. So i had to install a Comet tav30 and a 54 (instead of 60) tooth rear sprocket. I kept the 9 tooth jackshaft sprocket the same size. I guess this will give a slightly higher top speed, and slightly less off the line power. But frankly didn't notice a huge difference. The exhaust is a used rupp roadster exhaust. They fit really well on the MTD and come up on ebay a lot and not for much money.
I've never owned this model MTD with the removable handbars. It has a slightly different feel than the motocross style bar model. Still an amazingly great handling bike, these MTDs, and this one certainly is included in that.
Note the carb on this one. It's a Dellorto Ub22s2. Since the rupp style Dellorto Ua19s is frankly just too expensive (and hard to find), i wanted to play around with some different (and more affordable) Dellortos. This UB22s2 came up on ebay, complete with an angled mounting flange. It needed a couple parts, but overall was pretty complete. Clearly someone had put this on an angle mounted Tecumseh before, and the intake manifold was set up for that.
Since this is an "ub" style Dellorto, the float bowl arrangement is different than the "ua" version. If you look at a rupp you'll see this mounting style is different. I wish i could find out what these Dellorto abbreviations meant (ua, ub, s, s2, etc.)
So how does the ub22s2 work? really well! it's probably too much carb for the HS50, but it definitely gives a nice performance boast. Probably not worth the money (no Dellorto, regardless of the model, is cheap.)
Still have to figure out how to get an air cleaner on these Dellortos. The trumpet intake has no filter and no way to adapt one (easily). I'm sure there's a easy solution... cfh
