Well, it sure doesn't look pretty. How deep the scoring in the cylinder walls will determine whether you can salvage the block. Plenty of parts are available for this engine and you can get .010, .020 and .030 over pistons. I'd find a small engine machine shop and have them take a look at the block and give you a price to clean up the bore, if doable. If it's too much, there are several guys on the forum that may be able to help you out with a decent short block. You can find the blocks on e-bay, but buyer beware since you only see what the seller posts. Reputation is everything on this forum, so a seller here shouldn't screw you.
