So I'm putting a Tecumseh 6 H.P. on my Bonanza 1100, and as far as I know Taylor never made a muffler for a 6 H.P. so I
decided to make my own, scaled up a little larger. The exhaust port measures one inch so I bent some .090 wall tubing into the shape I needed. The bends ended up being to far apart so I cut and welded it. Next I made some dies on the lathe to press two 2 1/4 freeze plugs into the shapes I needed. I then made the flange, drilled the holes, and welded it all together. Even though it was a lot of work, I think I'm going to start over and make a muffler like the one that came on the Bonanza 1100. The one that has a short side and a long side from the seam and seven holes in the /end. The only problem is I have is I don't have one and I don't know if it has a baffle or a perforated tube inside. anyone know ?
