need help with sprocket choice.....
ok i have a blue h/f clone this is what i bought for it
22mm mikuni
billet flywheel.
.265 modified cam..
arc billet rod
flat top piston
14cc head and big valves
header exhaust custom made
mikuni fuel pump
advanced timing 8 degrees
bolt kit
and i have a 72 tooth sprocket now and i was wondering if i got a tav what size rear sprocket should i get 60 or 72 and i have a 12 tooth front clutch please help???:thumbsup:
delray
72 will still go fast,60 will go real fast..........:scooter: like 45+mph:thumbsup: you will be going so fast on the pavement that you will look like a block of wood hovering above a belt sander:smile:
Might re-think the 72 tooth sprocket. It may prove to be so full of torque that it wants to lift the front end. 60 tooth may provide a buffer so that you can start off without a wheelie. Wheelie's sound fun but, trust me, it can be a problem that takes away some of the fun of riding the bike.
