I am reserrecting this thread as I believe my that HF 6.5 also fits into this category. I also did read "supernova's" previous entire (long) thread on this subject. (I also noticed that supernova has since been banned- was it because of his advice on how to "modify" the governor?:shrug
Let me make it perfectly clear- I am NOT looking to have the HF engine over rev above the factory designed 3,600 RPM! I DO want it to reach the FULL 3,600 RPM potential, however, which I believe it is not (See below)
WE have 2 DB's with identical gearing and tire sizes. One has a Tec 6 hp "Powersport" with K & N filter (with unmodified governor). The other DB has a HF 6.5 clone with K & N filter and upgraded jet and emulsion tube (and unmodified governor) The Tec revs to a noticeably higher RPM and higher speed (estimated to be at least 5 MPH more) than the HF-equipped DB. The HF engine starts, idles, and runs very well. It just does not seem to get to its full 3,600 RPM, as the governor seems to cut in prematurely and causes some slight surging.
My questions:
Is the spring or zip tie method a legitimate (and safe) correction?
It appears that the (stock) fuel tank must be removed to accomplish this- How difficult to remove the gas tank? Any pointers?
I apologize upfront to the forum "powers to be"if this is a forbidden discussion topic. I am sure you will let me know if it is!
hmy:
