new bonanza project.
joshua. c.
This engine has the stock animal flywheel (Aluminum) and I beleve I gapped it to stock animal speck but I can check. I also have a damaged coil wire running to the spark plug that has been taped up with elecrical tape, It could be arcing to the block. This coil is the older type without the pvl flywheel and I haven't yet been able to locate a replacement. I also need to check compression just to cover all my bases. I do have another motor I could swap this with temporarily but it to would also need to be tunned since its a less extreme version of this motor built out of a briggs inteck 6hp.
joshua. c.
quick question: I think I have this bike geared to high. Dose anyone know how many teeth the gear on the clutch side of the jackshaft used to have on a stock Bonanza?
Recently I've been busy with all the prep work and repairs needed before installing new floors in my house. That major project is done, I just finished installing new hardwood maple floors by myself so I can take a break on the house and look at this bike again
I have new plugs on order for the bike to see if thats part of the issue. If push comes to shove I'll throw a stock briggs in the frame to get the bike running untill I get these issues sorted.
joshua. c.
Newengland needs a few more mini bike events next summer
A while ago we lost the East Provinence Rhoad Island 100 foot drags and it dosent seem they are coming back anytime soon. and the throwdoun group has been skipping the earlyest event they used to hold bringing them down to 2 events and a couple of years ago the go kart style trike racing group I was part of lost the tracks and stopped holding events and this year Gomas mini bike massacre was cansled. We need more events.!
I'm way to busy to host one but I'll definently attend anything new somone wants to start. Provided its not more than a 3hr drive frome New Hampshire.
joshua. c.
I may not be able to work on the bonanza right now due to the weather but I'm still working on other bikes. I just got finished prepping the rims of 2 bikes for new tires. I pulled the tires and wire wheeled the rust out of the inside of the rims then hit the inside of the rims with a coat of rust reformer and black spraypaint to prevent future rust. One bike is my black posibly either gilson or bonanza with a set of rupp 10 inch rims, the other bike is a rupp roadster 2 with 12 inch rims, both bikes are getting rupp motocros tires from Black Widdow Motorsports. Thise tires are a very knobby dirtbike like tire, I have used them on 2 bikes so far and I realy like them. I currently have 2 Rupp's in pices right now getting slowly assembled as I fix all the beat up detirioration issues. One bike will be bone stock and be a training bike for any of my frends and familys kids to ride the other will be an insane, stupidly fast, monstrosity of a bike meant only for the most skilled ridders.
I also have a therd rupp which will more or less be a prittyed up Rupp Roadster 2 meant to look mostly stock but with motor mods to make it fun, It will look like a show bike but run so much better and I wont be afraid to get it dirty. I build bikes to ride and for no other reason. This bike will be finished last after the other two. Imagine the looks of horror on the faces of other builders who build show only trailer queens when I troll them by showing up to a mini bike show with this bike just to run it screaming threw the trails the minute the show is over and come out coverd in dirt and mud lol.
joshua. c.
I know you guys like pictures so these are the rims ive been working on
All the rims have new tires new tubes and new rim strips. the top one isn't knobby but I just had a set sitting in my basement for my restomod prittied up Rupp project and I decided I wanted knobbys for that project so these will go on the stock rupp. The non knobby tires have been discolored in spots from sitting around and brushing against stuff tor over 5 years and theres a bit of overspray from painting the rims in chrome, I'll totch that up later.
I don't think the fake chrome came out as good as it could have. It dosn't help that I hired out the tire install after popping 4 tubes trying to get it right on my own. Whatever he used as a rim lubricant ate the chrome paint and melted it so they still need quite a but of totch up work.
The new paint on the bottom set was done after tire install and came out pritty good! only a few small spots of overspray made it under the tape. The chrome was damadged beyond repair so I didn't bother trying.
joshua. c.
Happy new years!
Newyears day update: One of those sets of rims ended up back on the bike today ready to run. This black bike (not my red bonanza) still needs some upgrades but its getting closer to finished. I need a better looking seat, a front brake setup, posibly a new swing arm setup for the rear, a handle bar brace to stop them from moving as much and a mikuni carb setup. These kobby tires will make a huge difference when racing allowing me to corner harder with more confidence. Untill my red Bonanza is running this black bike is currently tied for fastest with my blue bike.
As far as the bonanza I tested spark today and that was all good so next comes a compression test as soon as I find my guage. thes thing was somewhat running before so its probbably something simple.
If I can't fugure out what is wrong with my hevily modified Briggs Animal soon I still have options.
2 Briggs Animals I was told run when I bought them and 2 briggs intecks, one bone stock the other hevily modified. As long as at least one of these runs I will have this bike running next spring.
There are also like 6 or 7 other motors of varing sizes and makes hidding in the dark behind these. welcome to motor corner! lol. I keep spares of a number of sizes and tyes because you never know when that will come in handy.
joshua. c.
I think for now I'm just going to try to get either my lesser modded inteck or one of my stock Animals running just to get this bike running and play with the supper modded motor some more latter unless I find the issue soon and its a simple fix. Either way the bike wil look mostly the same, possibly with a black shroud based on engine choice. Even a stock Animal this bike will still be insane. Briggs and stratton states the Animal gets 9hp out of the box.
On a separate note I think I have this bike geared to high I think I need to swap the left side gear on the jackshaft with at least a 13 tooth. and keep the right side at a 9 tooth.
joshua. c.
life just got complicated. My truck and car are both down for different reasons the car needs heavy rust repairs and truck needs motor repairs possibley a full motor replacement. I had to buy a new car for the meantime to commute to work while I get ready to fix the old car (time consuming rust repairs) so my spare money is gone. I'm not hurting but don't want to dig into savings to deep and spend money saved for house projects on my truck right now. I may have enough saved back up by mid to late summer to spend on it but not right now. For now a trailer hitch on my car will be my solution for not having a truck. I dont know how many events I can make this year due to this, I'm probably going to have to skip Windber this year (costly trip). my car fix comes first right now so I'll have a backup vehicle again. I'm also working on insulating my normal bedroom right now and re finishing it's floors wile I've moved into the spare bedroom for the durration of the project so the house renovations are eating up some of my time right now. I'll get back to this bike soon but its not a top priority right now.
joshua. c.
Well my truck may be fixed I fugured out and solved the misfire. It's running smoother now but still smokes on startup yet to be seen if this will go away now that the misfire is fixed and I'll need to take it on a few long drives to be sure it cam make a longer trip. I'm still short on cash but having it running enought get building supplies for home renovations and do yard cleanup is a big realeaf. If it's reliable I may still make the Windber mini bike rally.
Windber is cancelled this year bud…
joshua. c.
Truck stopped smoking on startup now but picked up a tick possibly bad rod bearings. I'm not sure where to go frome hear. I'll have to talk with my mechanic.
joshua. c.
I Figured out the truck noise, it was a partly unplugged spark plug its running great now.
I finaly started taking a look at the bonanzas engine issue I poped the cyclender off to see why it wasn't firing and the cylender and valves looked ok but the way the head gasket easily separated from the head implied a head gasket failure. I'm going to try cleaning the head replacing the gasket and putting it back together. more updates once I do. I first need to figure out where I put the new head gasket after it arived.
joshua. c.
I have been considering trying a new tool I saw online that creates a ring in the block that creates a better seal to prevent blown head gaskets I cant be repeatedly fighting this issue while tuning the carb. I also havent been so gung ho on this project anymore ever since we lost Gomas Mini Bike Massacre. Thats the race that prompted this build in the first place. I now have a race bike nearly ready but don't have the race it was built for that realy took the wind out of my sails. There are other smaller races but they aren't the same and thier arent many of them near me. If windber returns next year I may premier the bike at that event. If not I'll have to find another option.
joshua. c.
also I dont think this bike is geared right so Im picking up a new clutch side jackshaft sprocet that is bigger to gear the bike down a bit. It's a 15 tooth to replace the 10 tooth on the shaft right now. I colden't find any info on what this bike origenaly had so just like the carb jetting it's the trial and error method for now.
Me & my dad both built 100ft drag bikes that have been sitting since Leadfoot stopped their race. So i understand that.
Is the Goma race definitely over? That sucks, thought i had heard it was coming back.
joshua. c.
I herd it was an insurence issue that canseled the event. I dont know much more than that. Untill I hear otherwize I woulden't count on it cumming back. I'm sure If there is a way to fix the issue they will try it because this was the biggest event in the hole area. We will have to wait and see, If it dose resume I'll be so happy!
