Thanks for heads up/concern. The flywheel and rod are on my list of things to buy (as well as valve/exhaust springs). I didn't plan on attaching the carb until I had the internals squared away.
I'm working on the bike later tonight (it's at a buddy's place), first thing I'm going to do it document the factory bolt patterns, I should be able to post those up way later tonight.
Hey guys/gals, sorry it's been a while since my last update.. I haven't been able to work on the bike since the last time I posted, but tomorrow I am definitely working on it and will hopefully get a ride in w/ the new clutch.
I finally got a ride in on the mini bike today, the clutch got me rolling I did not ride it enough to give any kind of review, but here are a few observations. It is possible to stall it when taking off, seems obvious but I wanted to point that out. My first start I stalled it and the second one it kind of wheelied on me slightly even at about 5mph when letting the clutch out. You can kind of feel the connection between engine and tire which is nice, like when you let off the gas you have a little bit of engine braking. We didn't try and wheelies or launches, it was just a couple of passes up and down the street.
With the nice 60 degree weather today it was a great chance for me and my buddy to go riding. I got the brakes temporarily put together today, there's a spring which is helping the arm return back down :no: That caliper may have seen its last days, but I am going to give it one more go at fixing it before I go the replacement or upgrade route..
I started tinkering with adding a car horn to the bike, but I want the switch to be hidden in plain sight so I decided to purchase a regular bike bell and turn it into a simple switch. I don't want to spoil too much about other electronic components, but there will be more to come
When the bell lever is pressed the "wires" (one is spring from a pen) coming off the red and green areas touch. I'm using a spring from a pen because this is just a prototype I have a video of it but I can't attach that inline from what I see so maybe I will make a better video later on and upload it to youtube and share.
We did some night riding tonight (I'm sure the neighborhood appreciated it) and I have to say the 3D is pretty cool so far! It feels like it puts down the power very well, my buddy said that might be because it's a new engine No complaints so far but I haven't tried to do anything fancy with it yet.
Just a small update, we got an LED light mounted on the handlebars. This is just a proof of concept, it won't be on the bike for too long I just want to see how it performs so that improvements can be made. The wood has been notched out on the underside to allow for the steering to go "lock to lock". A hole was also drilled on the underside so that the bolt on top of the frame is recessed into the wood. I'm still not sure how it will attach to the frame, right now it's using some ties (and the battery is 100% temporary and an eyesore :laugh. It was too cold out (and a bit late to be waking up the neighborhood) to give it a test run tonight but I'm looking forward to it.
Just another small update, I have the Hella horns mounted on the bike alongside the light. As mentioned above, the little bell on the handlebars is what is used as the horn button. I used to have these horns on a car, they are very loud (especially inside). The wiring was just to make sure that everything worked (it's not pretty), I will be using a better gauge wire and making everything look cleaner in time.
I was able to give the bike a quick ride and the headlight works super, it does exactly what it's supposed to do
Haha..those horns :devil2: you can get 16 guage 18" x6" sheet for like $8 homedepot ..cut it w angle grinder w chop off blade to make bracket for light ..shaped like a [__] w two screw holes on tree crossmember
you mean to line up engine mount holes? I just put clutch and chain on and line up straight, put a small bit of paint on a qtip and dip it in engine mount holes to mark the plate..not move engine till dries lift engine up and off..
I took the measurements for the engine holes but when I got home I realized that some of the numbers didn't make sense.. Next time the motor is off (should be very soon since I just got some engine internals in the mail).
That's a good idea, thanks! I have plans to do a little switch panel so the final version of the light/horn mount may still be bulky but not necessarily made out of wood
Some upcoming plans are to install my hotrodminibike hydro brake caliper (swapping in a right-hand brake lever), mount an ammo can (storage/battery box), some engine work, and split sprockets.
Thanks man, it's very entertaining I honked at my buddy one or twice when riding and he acted like it was a car so he moved over/looked behind haha. I have another identical fog light and I may run them side by side, it might be helpful (it's plenty bright as-is, I will be adding a low-beam high-beam feature so I don't blind anyone..).
I actually have one of those on a different bike (but thanks for letting me know had I been unaware ), but for this one I want to do something different I think it might have a cool aesthetic. I want to have some "auxiliary" buttons but more on those later!
