Hi,what gearbox are you looking for,the single or double stage,the single stage will gear you to 1800 rpms the double will gear you down to 900 rpms,much more torque.The single stage.usually have the output to the inside and have a sprocket for a chain saw on them,the 900 double will have the shaft coming out the back side with typically a 1/2 inch shaft with a flat on it,hope this helps:thumbsup::thumbsup:
