Old H30 needs some help
#23
thanx Shop Teacher, the first one is from an H35 and the part number is different from the one in my H30. May work but I am skeptical, the second one is part number 32555B, mine is a 32555A, i think the only diffeerence is mine is drillled and tapped , the one for sale is not? It should work. you got any insite on differences other than drill and tapped output end?
bikebudy
Banned - Must pay $500
#24
I'm not positive but, I see no reason why that crank would not work.
I would say its correct, other than its not drilled and tapped.
#25
Near as I can tell both cranks are interchangeable. The rod lengths are slightly different. OldMiniBikes sells a kit to accurately drill the center for the PTO (thanks, CarPlay). I'd go with the second one, as Bikebudy observed because it's really clean. Spend the money for a really good drill bit. As always, buyer beware on e-Bay and although the first crank doesn't look real bad and may clean up fine--but it could have burrs and nicks on the unseen bearing surfaces.
#26
The H25 through H35 cranks are the same, as long as they're all 1982 or prior. The later H35 has a larger magneto side bearing surface.
(Even though I am not a "real" small engine shop.) LOL.
Since the OP is probably going to ignore this post too, if anyone else needs one, I have one, scuffed up, 5/8 PTO, not drilled, but with puller pilot which works great to direct the drill bit for drilling and tapping. The metal is extremely soft, and you don't need a guide to drill it. Or at least I didn't. Journal is out of spec, but so is every other old ass Tec crank shaft.
Flywheel taper is a bit ugly, but that would be taken care of when the flywheel is lapped on during assembly. Or I could clean it up apparently and rip someone off on ebay for $60 by using bore hatch marks to describe a crankshaft, without providing any specifications to it.
I hear you can time these things by simply comparing the last guy's bolt indentations as well. (wink)
