Pic 1- Aluminum half-gallon tank made from two one-quart paint canisters. The necks of the canisters were trimmed down, but leaving a small 'waist' for a mounting band to fit into.
The two halves were fitted together in a bar clamp, preheated with a propane torch, and welded using an oxy/acetylene #1 tip and a neutral flame with Forney general purpose aluminum flux rod.
Pic 2- The brass band screw-clamps to a steel bung that is just long enough to prevent lateral movement of the tank when tightened without crushing the aluminum shell.
Cap and fittings are brass plumbing items from a hardware store.
Pic 3- Steel tank with mounting bracket made from an empty Coleman lantern propane canister. The brass fittings are brazed to the tank.
Pic 4- Another view...this tank was never painted or coated because it was designed to mount directly to a 15hp engine, and vibrated so badly during testing, frothing fuel, it was eventually scrapped and never finished.
