I would like this topic to focus on the smaller Baja Doodle Bug variants and our individual experiences. I am curious as to whether or not there have been improvements to the little mini or if there is a reason why my little Baja does (relatively) pretty well while other complain that they barely move in stock trim.
I bought my Baja Blitz a few weeks back. I'm located in Flagstaff, AZ elevation of 7200 feet or so. Out of the box it barely ran, but it came with a bulliten explaining that this would probably be the case and to open up the mixture screw on the carb. It still has a bit of a stumble but I suspect the elevation is just a lot to compensate for without rejetting the carb leaner.
After the initial adjustment I broke the engine in using the shipping oil for about 5 run hours leaving the governor intact at the stock specifications. I noticed things seemed to loosen up dramatically at this point. After changing the oil and rolling another 5 or 10 hours on the bike I loosened up the governor.
Now the little mini is a blast to ride around campus.
I ride it - I am 5'11 and 180 lbs. It accelerates slowly up hills and requires a light push off most times but is decently fast, and quick enough on level ground. Grass and dirt you need a run at.
My Roomates ride it - 240 lbs, 190 lbs and 170 lbs respectively. They all love it. The 240 lb guy usually needs a pretty decent push and can't take most of the hills on campus at all. I can take most of the hills on campus except for the steepest ones.
That is my experience. I think a single consolidated thread for this kind of thing might benefit our little sub "community". Perhaps someday this post may be the basis of a sticky in this forum for potential buyers and modders to look at.
