Hello ooklamock : Welcome to the OldMiniBikes first off to you and your trike. I looked up your belt number in my 1998-1999 Comet parts book. what you have is a 5/8 inch top width asymmetric cat99 belt. and has a comet #993-110 and the book gives two different center to center specifications depending on the diameter of the driven half of the system.
This belt if used with a 6 inch O.D. driven is 103/4 to 10-13/16 shaft to shaft spread.
If the driven half is 7 inch in O.D. then the distance is less at 9-13/16 to 9-7/8 inch
The belt measures 35.14 in circumference.
Worst part is the belts are obsolite and of course Comet as it was also out of business but another company is restarting production using the old tooling.
You might try contacting
Go Kart Parts | Go Kart Supply Online Catalog and see if they have any NOS belts.
Steve
