Perfect frame repair needed
I need to find a craftsman who can fix a crack and the bad covering it, the crack is through the weld now. Got the frame that way and it's an El Tigre upper where it joins the neck thats cracked and I need it fixed permanently , also there is a pitted spot where I want removed and a new section welded seamlessly. A couple of holes from screws and a footpeg bar removed and replaced. I need the welds to be perfect and the repairs to be invisible. This frame will be chromed again if I can get the proper repairs done. Otherwise I'll fix it myself and paint it rather than spend all that $. Again the work must be impeccable and structurally sound, if you know a welder fabricator of that caliber let me know. Thanks:thumbsup:
weld crack
Take your bike to a reputable body shop. Repairing a weld like yours is not hard at all. I restore old cars and minibikes . Couple of hours should take care of the repair.
