I am putting an H35 together after having received it disassembled. Mounting the ignition assembly (which is in one piece) looks straight forward but the plug wire seems to get compressed a good bit as the two bolts holding the assembly are tightened against the block. I see where I think the plug wire is supposed to fit so it snakes through to the outside of the assembly but I want to be sure before I tighten the bolts, particularly the bottom bolt.
There is also a skinny wire several inches long running across the top that is supposed to attach to something. I think I see that it should attach to a short and thin threaded post by using a very small nut but I am not sure.
If you don't have a picture, then if my rambling makes any sense to you feel free to use your fingers to type directions or advice.
Thank you so much!!
Thank you so much!!
