90 degrees to the wristpin as kustom kart said and about 3/8th of a inch from the bottom of the skirt. Pistons are ground with more clearance near the top to account for heat expansion. While I like to mike the piston and use a dial bore gauge to check bore a long feeler gauge works well to see if you are in the ballpark.
