plasti-kote metal flake
I've never used it...But I have used the duplicolor metalcast "sets" and it's pretty nice stuff! I dont think you'd even need the Plasti-Kote. Just prime it, use the Dupli-Color and then clear it...It should look great. Just make sure to hold the clear coat very close when spraying, so you get the "wet" shiny look. It's tough to do without running...but it'll look better.
i know its great stuff iv used the metalcast lots of times. 2 bikes in blue and 2 in green. Id just like to try somthing a bit extra with some heavy heavy metal flake rather than just the mettalic. I usually use automotive quality clear on them you can get it in spray cans its called jam-in-clear because its for door jams and stuff.
125ccCrazy
I tried the metal cast purple and I didnt like it , it came out too splotchy when going over silver base, I thought about using the metal spek blue and then the purple metal cast over that since they dont make a metal spek purple base.. as far as clear goes I prefer to use two part automotive urethane clear, so much of the rattle can clear has a yellowish tint to it especially if going over white or silver plus it has a tendency to get milky spots even in low humidity..
If you have an aircompressor and small touch up gun I'd suggest if using the purple metal cast to drain the cans into a jar and then spray it through the gun for a better even coverage..
the metal spek paint works AWSOME just prime and then aply the metal spek and clear it and you ge a unbelivable shine i used the metal speks red on my fox and it looks sweet in the sun all i did was spray can clear as well
Yes iv experienced the splochyness. I think thats mostly because of its translucent nature. You really need to pay close attention and put as many coats as you need to get even coverage. Also the base silver coat needs to be done well. It kinda makes touchups a pain because you need to prime silver color and clear otherwise you get problems. Its gonna be a while till i get this bike together anyhow so iv got time to expeariment with the metalflake. I didnt even start a build thread on it yet i want to get the frame in one piece before i do. :gunsmilie:
125ccCrazy
not the metal flake paint the translucent colors, sorta like a candy paint... It's used to simulate anodized parts... The flake paint works good since it's solid.... works great for a base color..
most of the slotchines is due to the round spray, to get a candy color (translucent) to lay out even and noy get clouds in the finish you really need an even fan spray like from a spraygun.. The trick to using candys or translucents is to base the project with a simular color like the metal flake blue with blue candy over it or if using a silver base to add some candy concentrate of simular color (red for red, blue for blue, ect), this will tint the silver and make coating with the candys easier with less coats to get a deep coverage.....
I think I'm gonna try the blue metal spek on my wifes Bonanza with maybe white rally stripes, leaning towards a 60's muscle car theme (look)... My Bonanza is going to be House of Kolor pearl tangelo....
the metalcast paints do have a fan spray tip on them. unless your thinking of somthing different. Makes it a real pain to paint tubing. Good call on the similar colored basecoat. I did that when using regular wimbledon white duplicolor paint on my jeep top. I used a cheapo gloss white over the primer first it really saved alot of coats and $
Agreed. it needs to be primed and make sure it dried fully before more coats. I didnt wait long enough and it had lots of runs.
joekd
I have used the duplicolor metal specks on my mtn bike swingarm, not really an "old school" flake pattern but for the price and ease of use it was a good deal
