A couple of days ago I started experiencing a missfire when pull starting. Typical for me is to turn gas on, full choke, pull start, as soon as I hear rpm's start to drop from full choke I turn choke off and ride off.
When the problem started I'd pull start, nothing, 2nd pull, Pow, 3rd pull, start up and ride off. I wasn't at home when it started. Made another stop before I went home and the same thing happened. Next day would not start at all.
Unless I'm riding fence lines around my property, right now, the majority of my rides are here to there affairs lasting 10 mins. or less
Approx. elevation 340' above sea level
180 lb bike/180 rider. 19" tires. 420 chain
100% stock predator 212, only throttle screw backed out.
Chinese tav2 8/72 gears. 2500 stall.
4000 max rpm. About 2000 idle rpm.
Approx. 15 hrs. run time. On 4th oil change. 5w30 Quaker State full synthetic.
.016 coil gap. Coil was slightly cockeyed from factory. top of coil at .016, bottom a little wider. I reset gap evenly at .016. No effect.
.003 int/ex valve lash. As found. I did not set lash. It is the same as checked after motor break in.
Flywheel inspected. No sign of any slippage. Stock timing (whatever that is ).
Carb cleaned and inspected. Gaskets from intake to ex. look good. No sign of leaks. No effect.
Bpr6es plug. 3 to 4 hours of run time on it. Changed from factory plug after 11 to 12 hrs. of run time. Gap .030.
Broke porcelain pic is my fault. Got in a hurry to take the plug threads off.
I put a new Bpr6es plug gapped at .029 and engine fired right up. Rode around for about 30 min. No problems but I have doubts.
I have ordered a full gasket set because I plan to pull the head and side cover and see if anything doesn't look right. Will probably lap the valves while I'm there. Not really a motor guy but I think I can handle that. Also check rod bolt torque while I'm poking around.
Anyway here is my question. It is my understanding that stock predators have a resistor in the plug boot.
Is it possible, by using a resistor plug with a resistor boot on a stock coil with a stock flywheel and stock timing that the spark is marginal at best, and after a little run time that is what caused the problem ?
I also ordered some bp6es plugs to have on hand. Any opinions are appreciated. Now I have to go pull weeds out of the garden.
