Hi All,
I've run out of ideas and instead of stalking the forums I'm actually needing help. I've tried everything I could find in regards to my issue.
I started my first predator 212 non-hemi modifications and I can not get this guy to start. Just in case I do live at 6,000. When I first got it put back together a few months ago after a ton of pulling it ended up starting up. It would take lot of consistent pulls to get that.
Here's everything I've done to the engine:
- Mod2 Cam
- 18lb springs
- ARC 6254 Billet Rod
- Flat-Top Piston (70mm, .570 Compression Height)
- Nibbi PE22 Carb - I've even returned and got a new one.
- Arc 6695 Billet Flywheel
- Set valve lash at .003 at TDC, verify lash after pulls, reset lash multiple times
- Try different/New Gas.
- Verified Mod2 cam time is set correctly
- Verified, tested and use couple of different spark plugs - Spark is fine and lash of starter is .030
- Using stock timer key as directed by Arc Billet Flywheel for the built in timing. Verified key is not sheared.
- Messed with carb settings, taken carb apart cleaned and verify things were working as expected. Replaced carb from 26mm to 22mm. Both Nibbi
- Tried engine starter with first carb
- Tried Drill start
