My T-Bird pit bike will hit "Ludicrous" speed. Only problem with that is with the street tires on it, you can lock up the rear wheel and it still takes forever to stop. Those 2.50 x 10's don't have a very big contact patch... New/better tires are waiting on me to install them.
Billet rod/flywheel, Mod 2 can, custom port job, 22 pound springs, header, high flow air filter, no governor, race fuel. Went down a couple of sizes of rear sprockets to try and keep the front wheel down. That still happens if you crank the throttle open...
The CT200u is another one that can fly, I still haven't wound it out yet.
Pretty much same same set up engine wise, has a TAV instead of the clutch/jackshaft. And am in the process of adding front brakes to it.
