SO taking pictures doesnt really work because the jet is way too small to get any definition.
I took the smallest welding tip cleaner and opened the hole. Went to the second tip and then the 3rd. Not sure if the 1st or 2nd did anything. The 3rd was getting some drag, so I kinda went around the hole till there was no drag.
Then smoothed the edge out. I re-installed the jet and drilled 3 holes in the front air filter cover.
I removed the slack out of the throttle as well. Definitly starts easier. Still though getting my 230lbs out of the hole is tough. I think I might open the jet up another tip size. Hopefully it will start better etc..
If all else fails, I will go to an #80 jet with the open air cleaner and make a header.. All of the parts are here...
affordablegokarts: 79cc Parts
Dave
