Hi all!
This thread will be dedicated to the repair of an old Briggs & Stratton 6B-S engine. I got this engine for free a while ago. It has very few hours on it (standard bore) and was stored without running for at least the last 25 years!
Needless to say, after sitting in a shed for so long, the appearance of the engine was horrible: surface rust, 2 decades of dirt accumulating, dead bugs and some things I don't even want to know what it might be! The gas in the tank was so old that it was all changed into a pile of wax! It smelled pretty bad too.
After an oil change and a few hours spent cleaning the gas tank and the carb, it started! I took a look at the internals and it has absolutely no wear anywhere. So, this thread will be more about cosmetic restoration, minor repairs and upgrading some parts.
Part 1: Recoil starter/flywheel
On these old engines, the recoil starter is one-piece with the blower housing. The recoil assembly is held in place by bending tabs that are on the housing. Someone before me must have wrestled a bit with the engine to replace the rope and broke all but one of the tabs. Great... So, I cut and filed smooth what remained of the old tabs and made some new ones out of 18-gauge steel that I riveted in place using small flat head rivets. Once the engine is painted they will be hardly noticeable.
Next comes the starter clutch. It was shot. I had a bunch of clutches from 5hp engines, so I checked if they would fit. The treads are the same but the "nose" of the crank was bottoming out in the clutch. I tapped out the plug on the end of the starter clutch and that took care of the problem. I had to slightly shorten the part of the starter pulley that engages the clutch to prevent interference. Then I made a new debris screen to replace the missing original piece. Done.
Next I trashed the old aluminium flywheel and obsolete magneto and replaced them with a cast iron flywheel and magneto from a late 3.5hp (yep, it fits). I kept the points for now but I can upgrade to an electronic coil later. I took out the air governer assembly and modified the air deflector (for lack of better term) of a 5hp to fit. I know it is crooked in the picture, I'll take care of that soon.
That's it for now. Stay tuned for some more progress as soon as I have some free time. Forgive these poor pictures, I'll take better ones the next time.
