I successfully drilled out a stuck screw head and then knocked it out with a punch. The inside of the wheel had a chalky corrosion dust from the unplated aluminum wheel. I would guess that I should paint the wheel inside and out to prevent further corrosion? I was planning to look for stainless steel screws and nuts to prevent another stuck screw; is that worth it? Were the GoPower Wheels on the Bonanzas the same brassy gold that I have often seen?
