All,
Looking to find a rear fender and brackets for a '70 Cat 400x. Some other parts I would be searching for if price is fair are front and rear wheels and hubcaps, and kill switch plate. Would be fine with a re-pop switch plate/bracket if any are available or made from anyone. Located near...
Hey, I have a set of 7 inch wheels with tires off my bronco mini bike available. Not 100% sure of the value but I heard the tires are hard to come by. Asking $225.00 thanks.
Does anyone know if this would be a direct replacement for the rear wheel on a 71 rupp scrambler? https://www.OldMiniBikes.com/-10-steel-wheel-chrome-plated-with-5-8-id-precision-ball-bearings-35-sprocket-and-drum-60-tooth.html
or could I get a plain wheel and reuse my stock brake stuff and...
Curious to find out what this is. The engine clutch is a dual pulley. the kick lever engages one of the two belts. The brake is an interesting set up as it has a belt wrapped around a pulley. any help would be appreciated
1 Pair 6" Manco aluminum Wheels. 1 half of one wheel has a chuck out of the flange area but still works.
$45.00 for both wheels, you pay the shipping.
Thanks for looking,
Jerry...
Looking for a couple of Burris wheels for a buddies drift trike. I have Burris cast aluminum wheels on my Drift Trike and they work well. He has True Roll spun aluminum wheels on his Drift Trike and they flex to the point that the sleeves wear off on the inside and are still almost full...
I have a nice set of 6" wheels I've decided to sell.
I don't believe they've ever been mounted on anything.
No sprocket, just the wheels.
Asking $100 plus the ride.
PayPal or USPS money order.
I have a couple of Duro knobby HF240 21-12.00-8 tires on order and have some questions... I'm new to all things Super Bronc 2 VT-1040 and ATV-style tire, are there any tips/tricks/step-by step procedures that I need to know regarding removing the wheels and bad tires from the super Bronc 2? I...
