I didn't notice the issue about 3 hourmeter's ago when I was testing different garter springs. That doesn't mean much being that I can be the least self aware person I know.
Comet 203589 belt on knockoff 30 series tav2. Looks like it's riding a little low in the 6" driven. Middle spring hole. Approx 15 hours on belt. 20 hrs. total ride time.
Stock 212, approx 360 lbs total (bike/rider), 4000 max rpm, 19" tires, 9:1 ratio (8t/72t), basically flat terrain (pasture/dirt road)
My first thought is the chinese red spring is starting to go bad but, being as this is my first rodeo, I have no baseline comparison for spring longevity. I swapped out to the comet green spring and I just ordered another comet belt. It may take some time to resolve this to my satisfaction.
Second thought is chinese driver is just a hair wide between the sheaves and when the spring gets a little used it opens up a little to wide. The original build plan was to come in cheap and upgrade on an as needed basis. Maybe happening sooner than anticipated.
Third is accelerated belt wear but I'm not seeing an excess of belt dust, pulley alignment and belt fit is good, driver bushing is good, and I'm not feeling excessive heat like I did when I was dialing in my gear ratio.
Could be a combination of factors. If anybody has any thoughts on the matter I'd be much abliged if you would share them.
