A brief about the first overall. Initially the machine was designed for the forest. How can I stop the forest, 10 kilometers, preferably in a straight line but to walk? The middle band is cluttered Russian forest, almost every 100-300 meters from the ravine 1 U20 depth examples, often with marsh and rivulet below. Of all the existing transport. funds almost always guaranteed that you will return from the forest on foot. The problem was posed - rover weight must not exceed 55 kg. that the average person could, if necessary, without a winch to pull it from any ambush. That's how this creation was born. Dry weight gain of 47 kg. (Affected interests in aircraft modeling experience). The second problem is the maximum reliability and maintainability under Russian realities. Paradoxically (in this title) margin and transmission frame turned even redundant. As we have not tortured, nothing to break failed, not counting the screws (which by the way quite a bit). And the third feature that somehow turned itself and totally not planned, it is an opportunity to pack terrain for a few minutes in the two bags. That opens quite interesting use cases, for example to take a train, bus, plane jump with a parachute with him, not speak already of the trunk of any car. Another feature is the simplicity of design and the possibility of recurrence of any workman little man.
Key performance characteristics.
5.5 hp engine. (modernized Ural 2T)
gears 3
max. speed 60 km. hour
wheel diameter 740 mm
track width 220 mm
tire pressure 0.13 kg / cm
Ground pressure min. 0.04 kg / cm.
clearance of 370 mm
steering angle of the front fork 55 degrees
Seat height 750 mm
5 liter tank.
weight 47 kg
disc brake on the intermediate shaft
Front-wheel drive chain from the intermediate shaft - double universal joint chain front wheel.
during disassembly min. (detached front fork is placed in the trunk of cars 80%) --- 10 seconds.
during disassembly max. (Two bags) --- 2 min.
