Sears roper question
Valocalrep
So i have a question, can anyone tell me the size of a sears roper front wheel bearing. i ordered some off OldMiniBikes and they sent the wrong size and i have no idea where else to get some at. Any ideas?
buckeye
If you measure the outside of the bearing that will give you the od.
Then measure the inside hole and that will give you the id.
Like SC said, should be 1 3/8 od and 5/8 id.
Valocalrep
Should be 1 3/8" O.D / 5/8" I.D. :shrug:
it is a 1 3/8 by 5/8, thing is it has a flange and i cant find anywhere that has it and the ones that were in the wheel when i got it are fully seized. OldMiniBikes is out and doesnt know when they will get new ones
Those ones might work
Steel Reducer - 5/8" OD x 1/2" ID x 3/4" L AZ2184
Maybe try to use the bearings they sent and get one of these bushings to take up the gap. I had to do this kind of thing on my El Tigre where someone had previously drilled the 5/8" rear axle mount holes out to 3/4".
Even with the spacer it has a ton of gap to be filled.
