Is 1 of the carb studs broken???? If so, that's a huge vacuum leak. Some thing jus looks odd about that carb.
Recheck the valve lash, set both at .003". Too loose on the exhaust will make it hard to pull, too tight on either or both will not allow it to draw in enough air/ fuel mixture.
