That spring came off the compression release that's on the exhaust side of the cam. Crank counter weight probably knocked it off.
That 58mm crank causes problems when the engine is not in spec in the bottom end. Every thing needs at least .030" clearance, from my experience with the 58mm crank.
Crank and cam endplay should be .010"-.012" to keep things straight down there.
