Okay, so I took some pics and tried to do a drawing of the problem I am having with the throttle cable.
When I turn the throttle twist grip with the regular throttle cable attached, the tubing that the cable runs through moves out of the slot, instead of just the cable moving inside of the tubing.
I tried to rig something together originally with some bicycle throttle cable and some extra plastic cable tubing I had, and wrapped it in electrical tape to hold it in place, but after a certain number of bends, the plastic snapped and it bowed outward, and wouldn't turn, or turned with much effort and difficulty.
Is there an easy way to fix this?
I don't mind using "unorthodox throttle methods", but I would rather have control up by my right hand for throttle adjustment, as at higher speeds, the current method I have rigged to the seat makes me a little uneasy.
